Problem with Adaptive Front lighting System (AFS)
So the other day I was parked next in a garage and facing a wall, and I wanted to test the adaptive front lighting system, i saw that the right headlight worked, but the left headlight did not respond. I turned both directions, tried this many times, and saw results from the right headlight but not the left (drivers side). Is something wrong with my AFS?
It won't turn left because drivers coming towards you are on the left. It only turns right so you don't blind the traffic coming towards you. It is like someone not turning off their brights. If it turns to the left at all it only does it by a minut amount but from what I remember reading IT DOESN'T TURN TO THE LEFT.
only after you get to 25-35 mph range will they both work.
Already had asked dealer,last service visit.
complety normal.
superjoey
31
03-22-2023 11:56 PM
