Headlight and fog light bulbs what do you guys prefer
if u want to install both dlrs and d2s bulbs, i recommend jacking up your car, take off the 2 front wheels, unclip the linings to reach the back of the housing. I think this is the easiest way to access where the bulbs are. The rest is just plug and play but be careful with the hid bulbs b/c they are VERY fragile and make sure the wire connected to the bulb is under the bulb when u situate the bulb into the housing itself. The hard part is getting the x clips out of the way when putting in the bulbs. I'm not sure if u would need to but unplug your battery as well just for safety.
Originally Posted by homelessdrunk
how much did you pay for just bulbs i can never find mccullough BULBS only damn kits and dont want to spend that much for some bulbs... since im not gonna use the kit
http://www.hid-sin.com/mcreplacements.htm
http://www.ultrabrightlights.com/pc-...d-bulbs-2.aspx
http://cgi.ebay.com/ebaymotors/5-x-1...spagenameZWDVW
I have different ones in there now because the LEDs in the previous ones kept going out for some reason.
https://www.myg37.com/forums/lightin...00k-8000k.html
^ Check out the group buy on the Mcculloch HID replacement bulbs. I highly recommend these bulbs. They are very comparable to Philips and other oem bulbs and are priced very competitively.
superjoey
31
03-22-2023 11:56 PM
bikerjosh
08-19-2015 11:26 PM
