Steering Wheel Height
Old 07-03-2008 | 11:56 AM
liscmad's Avatar
liscmad
Just wondering if it was just me or does anybody else wish their steering wheel would go lower than it does. IMO it needs to!
Old 07-03-2008 | 12:21 PM
Graham's Avatar
Graham
I thought so too when I first got my car, I've since adjusted. Just like you will learn the lean technique to kind of see out the blind spot.
Old 07-03-2008 | 03:13 PM
bboysteele's Avatar
bboysteele
You know you can adjust it right?
Old 07-03-2008 | 04:10 PM
pass1over's Avatar
pass1over
I wish the do0r was lower or the armrest was higher, so I can lean my left arm on something when driving.
Old 07-03-2008 | 07:08 PM
Graham's Avatar
Graham
My arm falls asleep if I put my arm on the window sil.
Old 07-03-2008 | 07:13 PM
gan78mao's Avatar
gan78mao
yea the window sil is too high !!
Old 07-03-2008 | 07:37 PM
TomG37's Avatar
TomG37
The wheel does move up and down if you didn't know already, also I think it goes low enough.
I have always had a problem with the arm rest height on my door. The arm rest is too low to hold the wheels. and the window sill makes my arm sit in a weird position.
Old 07-03-2008 | 07:50 PM
gan78mao's Avatar
gan78mao
^Thats what im talking about!
i believe alot of us ahve the same problem
Old 07-07-2008 | 12:54 PM
jackjohnson's Avatar
jackjohnson
liscmad, I agree with you 100%. The wheel does not go low enough, even adjusted at the lowest position. For most people it's probably not an issue. Since I am so tall (6'3") and have to completely lower the driver's seat to the floor so I don't bump my head on the roof, it makes the wheel seem higher. The only way I've found to compensate are to do 3 things:
1 - Don't put the seat all the way to the floor. Find a happy medium. The higher the seat, the lower the steering wheel will seem.
2 - Move the seat in toward the wheel a little more than you normally would. This way, you can move the wheel away from you slightly, effectively lowering it a little bit (because the cluster is at an angle).
3 - Move the wheel in a bit (see #2).
This helped me, and I've found a relatively comfortable driving position. Not 100% ideal, but close enough.
Old 07-09-2008 | 08:23 PM
Sunny81's Avatar
Sunny81
Maybe I just don't understand because I'm 5'10'', but the power telescoping wheel/gauge cluster pretty much lets you have it set up at any height and angle.
Old 07-09-2008 | 08:27 PM
IP37's Avatar
IP37
yea i wish it went a bit lower. i noticed that the first time i sat in the demo g37 they had at the dealer
i'm used to the steering wheel being low. every car i get in, i put the wheel as low as it goes
helloandchau
10-06-2015 05:26 PM
m3clubracer
09-07-2015 05:14 PM
Sylo
09-03-2015 04:44 PM
Quick Reply: Steering Wheel Height
