The unwanted Noise / Sound Thread
#47
#49
I hear a lot of wind noise when im driving 30-50 mph. IMOafter 50 the engine takes over the sound. I also hear white noise on the center speaker in the front deck (BOSS).
JY
JY
#50
I have whine on first and second which is pretty noisy then gets quiet after third... cant hear so much past 4th...
Anyone have this problem? I thought it was just a characteristic of manual cars..
Also does the car jerk a bit if you let go of the gas in first?
#51
My car did the same whine noise in first and second. My transmission had to be replaced. I no longer hear it with the new transmission.
#52
Moonroof pops loudly when going over uneven ground.
Random pops and creaks from the dash and glovebox.
Creaking noise from drivers seat on cornering.
Harmonic rattle from gearshift at 5Krpm and in 3rd and 5th gear. (6mt)
On my 4th muffler.
Never had a noisier interior.
On my 4th muffler.
#53
On my 4th muffler.
On my 4th muffler.
You guys must own a spin off G37 made in China because mine is silent as a tomb inside at all speeds. Maybe you did get a lemon.
#54
2009 Journey - all kinds of creaks and rattles, 600 miles on it!
Right ac vent area creaks over bumps
Right door rattle over bumps
Right door speaker rattles over low frequ.
Glove box rattles over bumps
Random center console rattles.
Lord! +I have the Whine of death....
#55
Please post issues relating to rattles, noise, vibration, squeaks, etc.
Here is the list of know noise / sound issues so far:
1. Muffler Rattle (Cold rattle and other) - Know problem, dealership can fix.
2. Clutch noise when foot off in neutral - Nature of the beast ?
3. Speaker hiss / whitenoise - Am i the only person that hears it ?
4. Moonroof rattle - Some of us so far
5. Ping noise when shifting in low gears - Nature of the beast ?
6. Rattle in Door -
7. Wind Noise -
8. Noise From Bank 2 Vvel Actuator - TSB issued
Lets try and keep this thread going, and hopefully it can serve the community here.
6. Rattle in Door -
7. Wind Noise -
This is now the only issue I have however the dealership has told me that it is "normal".
#57
I GOT ONE!!!
Tapping sound coming from the passenger side dash. Happens when you go over bumps or when the road isn't smooth. If it sounds like plastic-to-plastic tapping, check the cover for the air filter behind the glove box. It's a white plastic piece about 3"x8" long. Make sure the thing is locked into place, it should not move at all when properly installed. In my case, I hear this tapping sound only when I use my A/C. I think when I had my 15K service, the tech didn't install the cover properly.
Good luck!
Good luck!
#58
LA G Club
I GOT ONE!!!
Good luck!
Good luck!
Oh dame man!!! I have this sound going on, and it is on the passenger side only. I thought it might have been my intake box rattling, but now that u posted this I know what it is. Sweet, thanks for the solution.
#59
Make sure it locks into place. Push the cover to the left, the teeth should snap in, then lock the other side. It should not move when locked.
Instructions for removal here: http://www.infinitihelp.com/diy/gsed...eplacement.htm
