Notices
Exterior & Interior Light Specs/Sizes
Old 03-12-2013, 03:23 PM
  #76
dragion
dragion's Avatar
Originally Posted by xorbitman
Has anyone replaced the front turn signals yellow bulbs with switchback LEDs? In case there are some of you who don't know what switchback LEDs are: They come in different stacks...30 stack or 60 stack for example and the there are 2 types of leds in the stack. for example the 60 stack has 30 yellow (amber) LEDs and 30 white/blue leds. The reason it's called a switchback is that when you put your turn signals on the leds will blink amber as a regular legal turn signal and when you are driving they stay blue. I did notice that the regular ambers do not stay on when you're driving as they do on many other cars....although this is easy to modify.
I've updated mine to switchbacks...ordered from V-Led.
Here are the ones I bought:
6K TYPE 2 DUAL COLOR CHANGING WHITE AMBER SWITCHBACK 48 PARKING/TURN SIGNAL BULBS 7443 7443NA | 1 PAIR
Will also need these for hyperflash correction:
LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX | 1 PAIR - Resistors
Short Video:
http://s1342.photobucket.com/user/dr...551a6.mp4.html
http://s1342.photobucket.com/user/dr...e4315.mp4.html
Old 03-23-2013, 06:50 PM
  #77
WhatupBreal
WhatupBreal's Avatar
Lightbulb Headlights and Foglights G37xS 2011 bulb replacement help
I'm trying to replace the bulbs next to the headlights so they match the headlight color I'm sick of the amber looking color, does anyone know what bulbs I should buy to get this fixed same with the Foglights I want those to also match the headlights. I have a 2011 coupe G37xS. Any help would be much appreciated.
Old 04-06-2013, 07:49 PM
  #78
JEspada
JEspada's Avatar
Does anyone know if you need Ballasts for fog lights when only changing the bulb to an HID bulb?
Old 04-07-2013, 12:37 AM
  #79
dragion
dragion's Avatar
Unless the fogs has already been updated to HID, then the bulbs can be replaced with just a HID bulb replacement.
If the fogs are stock, then a HID kit with ballasts will be needed.
Old 04-07-2013, 12:54 AM
  #80
dragion
dragion's Avatar
This exactly what I did for my G37xS sedan.
PM already sent
Old 04-10-2013, 12:00 AM
  #81
kimono
kimono's Avatar
pm me also pls thanks..
Old 04-15-2013, 03:05 PM
  #82
JEspada
JEspada's Avatar
Fuse for Parking light?
Does anyone know where the Parking Light fuse is located and which fuse box is the fuse in? I know where the fuse boxes are, I just need to know where the fuse is?
Old 04-23-2013, 03:48 PM
  #83
gismyluv
gismyluv's Avatar
I try to replace the vanity light with a 12 LEDs festoon bulb and blew the fuse. Is it because the LED is drawing more than the regular bulb of 2W or I accidently shorted the contact? Thanks.
Old 09-24-2013, 12:13 AM
  #84
Chulodee
Chulodee's Avatar
Does anyone know what size bulbs for the 2010 G37X? So many different bulb sizes keep coming up smh
Old 09-24-2013, 12:14 AM
  #85
Chulodee
Chulodee's Avatar
^^^fog lights^^^
Old 09-24-2013, 08:35 AM
  #86
TONY37X
TONY37X's Avatar
Coupe or Sedan?
Sedan is H8 for Fog Lamps
Old 09-24-2013, 08:53 AM
  #87
TONY37X
TONY37X's Avatar
Originally Posted by AllReD
Can any of you guys tell me which part from VLed would replace these bulbs? (parking or city lights)
I'm looking for 5000K, equally bright or slightly brighter that the current stock bulbs.
Thanks.
These are 194/168 Mini-wedge stye, there are tons of options out there, the latest ones I've tried are the Osram 11-Watt in Super White. They really fill out the lense nicely with a bright white/hint of blue.
Lots of other Choices: 194 168 W5W 2825 Map Led Parking Signal Marker Bulbs
WLED Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
Update: I no longer recommend the Osram 11-Watt from Autolumination for the city lights/marker lamps, they seem to overheat and shut off after 30-45min of being on. They are bright, but guess not made for constant on, oh well back to the vled versions I took out.
Enjoy!
Old 09-24-2013, 07:01 PM
  #88
Chulodee
Chulodee's Avatar
Originally Posted by TONY37X
Coupe or Sedan?
Sedan, sorry i didn't mention
Old 02-10-2014, 02:23 PM
  #89
IEMaestro
IEMaestro's Avatar
Can someone help me please?!? Im trying to find the bulb size for the glove box bulb in my 2011 sedan. I have searched, but havent found a definitive answer. I have read many threads and found three different bulb sizes for the glove box: 57, 37, and 74. Which one is correct? Thanks!
Old 07-05-2014, 10:56 AM
  #90
MCarig37
MCarig37's Avatar
Which bulb would I need for the amber strip in the headlight housing?
Quick Reply: Exterior & Interior Light Specs/Sizes
