Exterior & Interior Light Specs/Sizes
#62
I had a few small issues with the speed side of my exactmat. I've put it down to it being worn.
No issues so far with the control side.
Might look better if you kept the inner taillights but filled in the license plate area and then moved it to the bumper.
bubble shooter
bubble shooter
#64
Tony, are these the one's you bought for your front markers?
6K WHITE 6 LED HIGH OUTPUT BULBS W/ HEAT SINK 194 168 158 | 1 PAIR
#65
6K WHITE 13 LED LIGHT BULBS 158 168 194 2825 | 1 PAIR
For all your other 194/168 applications (Maplights, Dome, Doors, License Plate) I highly recommend these:
6K WHITE X5 HIGH POWER LED LIGHT BULBS 194 168 158 2821 | 1 PAIR
#66
#70
Simple question:
Want to upgrade the 2 front map lights in 2012 G. I have quite a collection from my old Acura. Can someone tell me what type of bulb it takes so I can find the equivalent LED?
Is the dome covers hard to pop off?
#72
#75
Has anyone replaced the front turn signals yellow bulbs with switchback LEDs? In case there are some of you who don't know what switchback LEDs are: They come in different stacks...30 stack or 60 stack for example and the there are 2 types of leds in the stack. for example the 60 stack has 30 yellow (amber) LEDs and 30 white/blue leds. The reason it's called a switchback is that when you put your turn signals on the leds will blink amber as a regular legal turn signal and when you are driving they stay blue. I did notice that the regular ambers do not stay on when you're driving as they do on many other cars....although this is easy to modify.
