Exterior & Interior Light Specs/Sizes
#46
Does anyone know what fog light bulbs go in a 2010 G37 convertible. I had ordered a HID
H1 kit through DDM and my infiniti dealer said it was the wrong size bulb cause it didn't fit through the small opening?
This model has the fog lights in the same housing as the headlights and parking lights.
I'd prefer HID but if there is a good bright white or slight bluish tinted LED I'd take that as well.
Please help. I've already replaced the parking lights and Headlights and want to get rid of the nasty yellowish fog lights.
Thanks in advance!
Thanks in advance!
#47
DS2 bulb. (2010 37x) I have seen many replacment bulbs (want to go to a 5k or at most the 6k color.) I have seen prices from $40-$140 per bulb.
Will using the cheaper ones cause any electrical issues or dash warnings, fit issues? Many sites say factory direct replacment. What brand are ours and anyone have the specs on them?
Could I ask any more questions lol, thanks, did not see anything in my searches other than DS2.
#48
#49
What's the correct size for the parking and turn signal lights for the 2010 G37S sedan? I'm trying to get rid of the amber look on the headlights except when I turn on the turn signals, anyone know when I can get them? At night it annoys me when I see the yellow in my headlights when though I have 6k headlights
#50
Interior: Map Lights 2 x 194 Style LEDS / Puddle Lamps 2 x 194 Style LEDS (One in each door) / Rear Reading Lamps 2 x 194 Style LEDS (One in each) / Trunk 1 x 194 Style LEDS / Glove Box 1 x 57 Style LED / Front Vanity Mirrors 2 x 29MM Vanity Style LEDS
Exterior: Reverse Lamps 2 x 921 Style LEDS / License Plate 2 x 194 Style LEDS / Front Marker Lamps (Upper Outer Corner of Head Light) 2 x 194 Style LEDS (One each side) / Headlamps 2 x D2S Style HID's / Fog Lamps 2 x H8 Style Halogen Bulbs or LED or HID Conversion Kit / Front Turn Signals 2 x 7444NA Mirror Style Bulbs or LEDs with resistor fix.
* All Available on www.v-leds.com *Except the 7444NA's
#51
Thanks Tony, just the information I was needed.
#52
Could you tell us what dimensions the bulbs are? I am on the v-led site but there are like 3 or 4 different 194 bulb dimensions. Thanks.
#54
Help! I bought a 2008 G37 Coupe 6MT about a year ago with Halo's already installed on the headlights. About 6 months ago, the right Halo stopped working. Then a month later, the left one went out. About a couple of weeks ago, my front right headlight started to flicker on and off- and now the low beams and high beams on the right side are both not working. Now my left headlight is flickering. Any suggestions of how to trouble shoot this problem? Thank you in advance.
#57
i also have garax bulbs, as well as V-led hid fogs (which are my DRL) and they dont really match, Garax is much less bright then the V-LED kit. So my DRL's are brighter than my headlights atm.
#58
#59
#60
