anyone else hardwired their V1?
Here's a link to pics I posted in another sub forum. Mike's mount and Stealthcord.
https://www.myg37.com/forums/audio-video-and-electronics/179073-pics-of-mikes-mount-and-stealthcord.html
I did mine today with my bel vector. It had a barrel power cord and I emailed invisacord and they walked me through how to wire it... it was easy... cut and solder and heat shrink and plug in... no more wires hangin... W00T!
I bought this mount.....believe in the 23mm.
http://www.countryjoycrafts.com/350Z/valentinemount.htm
V1 ftw.
I bet this looks cleaner than most installs. It's something I considered, but chickened out.
PM me if you wanna chat about it... I could walk you through it with out any problems... it was way easier that I thought it would be too... let me know...ill even send you some heat shrink if you need it...lol Radio shack raped me into buying a bag full for 3 bucks... but it was convienant...
#30
Now, IF the invisicord is red and black, red being power (12V) and black being ground. Install the red probe in the brown slot just under the wire and the plastic harness. Should be pressed to hard. But will be secure. Then insert the black into the black as same as above. You also take the harness clip out of the mirror for better access. Again, I'm not sure how the product you have is set up.
