A Few Lighting Mods (Lotsa Pics)
#91
Originally Posted by rrevin
Please post for all to enjoy :-)
31mm x 5mm diameter (Chrysler & Others) $7.99 each for Visor vanity mirrors. Super White. Order 2.
194 5-LED wedge matrix bulb. $6.99 each. I used these for both overhead map lights and both door courtesy lamps. They can also be used for the license plate and trunk as well. Order 7.
I ordered PIAA Xtreme Super White from Amazon.com for $9.99 (Twin Pack) for the parking (city) lights. My hands are way too big to get in there to change these out so I'll have the dealer do it for me when I go to get my plate.
These are the ones I used. Some chose others with 6, 9, or 12 LEDs, for different applications like the trunk or license plate. All of the LED's can be ordered from autolumination.com. They ship quickly and were very helpful when I had to return some that I had ordered incorrectly.
Hope this helps.
#95
#97
Pull down the visor. On the right side of the lens cover you will see a small tab as referenced in the photo below. Insert a small screw driver under the tab and gently pry up. The bulb is directly under the lens cover, just pull out the stock bulb and put the new one in.
thanks alot! ordering my bulbs today
#99
Hope this helps.
#100
Took my car to the dealer today to change out my city lights. I was promptly told that it cannot be done without removing the bumper or going in thru the wheel wells. Anyone who has done this, can you post step by step pics as I know the dealer is incorrect! Also, has anyone replaced the front turn signals yet? They also state it cannot be done without removal of the wheel wells...
#103
Superbrightled lights/interior
I just installed the lights that were recommended from superbrightledlights.com. I put cool white 5-LED all around. For the doors, I installed the blue 5-LED. When I open my door, the blue light from the door slightly floods the ground....adds a nice touch when your exiting your G. Thanks for the info....it was a quick and easy upgrade and it looks great.
#104
okay: autolumination has 9006 LED bulbs that look fairly bright! I was thinking that I would replace the fogs (which I never use) with them for aesthetics. Any thoughts on this????
#105
