A Few Lighting Mods (Lotsa Pics)
#242
Pull down the visor. On the right side of the lens cover you will see a small tab as referenced in the photo below. Insert a small screw driver under the tab and gently pry up. The bulb is directly under the lens cover, just pull out the stock bulb and put the new one in.
#243
31mm x 5mm diameter from autolumination works perfectly, i tried it myself.
I am not sure if the 33mm x 6mm would fit, it's too big.
On a side note, i ordered from superbrightleds.com (7 5wled bulbs) and 1 wasn't lighting. They sent me another free of charge, without any questions asked.
wicked customer service if you ask me.
#246
#247
just replaced my lights today : door panels, map lights, rear license plate and the trunk...but i have an issue for the one in the trunk...i used the 12 LED inside the trunk...i know i read the thread before...but my question is, which led will fit the trunk with the plastic dome on, and which is bright or close to 12LED. I went with 12LED for map lights and 5Led the rest....looks nice.....next I need to buy the ones for vanity mirrors...I got the LED from Superbrightled.com...good stuff.....
#251
