Help Fuse Tap Question
Fuse Tap Question
I’m installing a A139 Pro Dashcam. Does it matter what orientation that “ actual “ fuse goes inside the slot of the fuse tap? Ik the old fuse goes on the bottom.
I’m saying my ACC fuse is 20A but it’s upside down in the fuse box so it looks like 02, where the left side gets power so the 0 of the 20 would be getting power. Does that mean I would put it the same upside down when I slide my fuse in the fuse tap. So the 0 part of the 20 would be on the outside of the fuse tap
SkysG37 (07-22-2023)
No, fuses are not "directional" components so it doesn't matter which way they're inserted. All they do is limit the amount of current allowed to pass through by using a small specific size or type of wire internally between the two connectors. If the current draw exceeds the rating, that small wire overheats and literally burns the connection. Thus a "burned out fuse".
ILM-NC G37S (07-22-2023)
True, the fuse is not directional.
but the "tap" is.
If the accessory you're adding doesn't get power, flip the tap over.
but the "tap" is.
Solved :)
Appreciate The Replies, I Was Able To Solve My Original Posted Question That Day Ill Leave The Post Up Incase Others Have The Same Question. Thanks Again For The Comments!!
hi I need help I installed a tap fuse and used the 10amp ignition fuse I installed the tap fuse the wrong way and saw a spark and now my ignition wont turn on.
Unhook whatever accessory you are trying to add and replace the original fuse without the tap.
ignition work? Good
Figure out why the accessory shorted. That fuse did it's job.
Still no ignition? ****, time to figure that out before continuing on with the accessory install
Note: don't tap into the ignition circuit next time.
ignition work? Good
2009G37Bandit
12
07-04-2012 08:38 PM
KRAZY J
Future Models
25
01-02-2008 06:42 PM
