Need some help to UnFK my reverse cam. Wiring harness routing?
So, My G37S Coupe with bose and Navigation
I had to disassemble the whole interior for a water intrusion issue. (mold)
I replaced the drivers seat, the carpet etc.
Anyway, after I had removed the middle console to replace the carpet and reinstall the new carpet and got everything back together the reverse cam just has a blue screen. Chances are I missed a connector somwhere in that area, but I've checked it over several times and I cannot find anything.
Does anybody happen to know the routing of the wire harness for the rear view camera up to the front so that I can find each connector or check for continuity from the rear cam to the AV unit.
Also does anybody know the location of the backup camera module?
I tried all the self tests and no errors were noted on the AV unit in all of the setting.
Thanks for any help
-John
Thanks for any help
-John
Ok, this will be hard to put into words.
If all you disconnected was the center console and seats, then check connector M144/B207. This is a 12-position, white, square connector that should only have four (4) wires: two (2) black, one (1) red, and one (1) white. This connector is located toward the rear of the center console and is the main junction/connection between the camera and the AV unit/Display.
From M144/B207, the wiring follows a path "south" under the floor, to the passenger side wheel well (connectors B66/B243), through the bulkhead to the trunk, up to the decklid (connectors B27/B301) and ultimately to the camera (B305).
From M144/B207, the wiring follows a path "north" through the center console to the dashboard. From there, two (2) wires (power & ground) connect to the AV headunit while the other two (2) wires (signal & shield) connect directly to the display:
This info is from the 2013 G37 Coupe FSM. I doubt seriously there are any differences between 2013 and your 2010.
2010+ models, with NAV, do not have a Camera Control Unit as this module is integrated within the AV headunit itself.
Whew! Hope some of this makes sense and helps.
SonicVQ (05-21-2020)
This was a small 4 wire 4 socket connector though.
I have a camera again. Thank you
Chris Olson
03-28-2024 09:46 AM
