Is a 1000 Watt RMS amp pushing it?
Old 02-10-2020, 01:25 AM
RA081224
RA081224's Avatar
Originally Posted by Jsolo
Hearing loss is inconsequential..
I fail to see the significance of speaker impedance. Be it 1/2/4Ω. If the system as a whole is consuming 1000 watts, it's 1000 watts regardless of the load. I vaguely recall reading a spec of 150A for the stock alternator, so if you'll be driving that much speaker, more batteries/caps will be needed. I also recommend some of these - https://www.amazon.com/Professional-.../dp/B01BEENYCQ .
Just one caveat that makes this even more troubling. If an amp s rated at 1000 watts output, it will draw more than the calculated 83.3 amps since there isn't an amp in the world that's 100% efficient.
Old 02-10-2020, 01:32 AM
RA081224
RA081224's Avatar
Originally Posted by stealthee
A capacitor is a hindrance and not a help. It literally adds MORE strain to your charging system. The only way to properly fix dimming lights is to upgrade wiring, or upgrade the alternator.
I read your linked article and agree with most of what the author states. However, an audio capacitor is to help bolster transient response of the amp only. If the electrical system of the car and the wiring cannot supply sufficient current for the quiescent operation (steady state) of your amplifier is when the concept of current limited systems come into play
Old 02-23-2020, 08:46 PM
milosz
milosz's Avatar
Location: Chicago home of the 2016 world-champion Cubs!
Keep in mind that an amp with 1000 watt output is only 3 dB louder than a 500 watt amp.
If you want to have DOUBLE the loudness, you need TEN TIMES the power. Human perception of volume is logarithmic in relation to amplifier power. So a 1000 watt amp is*NOT* ten times louder than a 100 watt amp- a 1000 watt amp is only TWICE as loud as a 100 watt amp.
llebcire (02-23-2020)
Old 02-24-2020, 08:49 AM
Surfnazi
Surfnazi's Avatar
point of getting higher output amp is so you dont have to run it at full output killing the life of it faster. I run my 1000/1 at 40-60% gain
JT2014
09-09-2014 08:55 AM
Reiki_Rocket
04-26-2010 09:21 PM
bllop
11-03-2008 04:47 AM
shepa
07-11-2008 03:12 PM
Katastrophic
04-02-2008 05:09 PM
Quick Reply: Is a 1000 Watt RMS amp pushing it?
