2011 G37 Convertible - Where is 98800JK600 MEMORY ECU ECM COMPUTER located
2011 G37 Convertible - Driver's Seat memory Buttons don't respond
Hello
The Driver's Seat memory Buttons don't respond and do not light up
but the drivers seat can be adjusted manually with the side adjustment buttons
The Driver's Automatic Seat Positioner also does not operate
but the Mirrors, Steering wheel and set can be manually adjusted
Fuses #9 and #10 test good - are there other fuses to check?
So would the next step would be to replace the Automatic Driver Positioner System Unit
or The Seat Memory ECU 98800JK600
Does anyone know where the Driver's side Power Seat Memory Control Unit is located in the vehicle
If the image from manual below is correct then I guess under the dash / left of steering wheel?
OEM part # 98800JK600
The Automatic Drive Position (ADP) module is located under the dash between the steering column and the center console.
From what I can tell from the catalog/diagrams...
ADP- p/n: 98800-JK600 ($492.06)
Driver Seat Control Module- p/n: 28565-1ND0C ($744.36)
Part numbers taken from discountinfinitiparts.com for a 2011 G37 Convertible (prices effective 12 Nov 2019).
HOWEVER, I would strongly recommend that you contact discountinfinitiparts.com (or a parts supplier of your choice) and provide them with your VIN. They will verify the part numbers and then you can go from there.
kimmspeed
General Tech Questions
42
03-27-2023 04:04 PM
Danjjacob
12-25-2017 04:41 PM
