Help Screen radio and a/c stops working
Hello everyone!
When I' did instillation of GPS unit under the steering wheel and when I'm trying to find a hot spot I touched the hot spot and ground and looks like I did a short circuit coz my screen, radio and a/c regulator stops working.. I'm a dumb but it's whatits and I have to fix it now. I checked all fuses for radio navigation and blower and they all fine.. I hope I didn't burn it.. Any help or idea would be great
Code U1000 refers to a problem in the CAN circuit. In this case specifically with the AV not transmitting/receiving signals. Determining what short circuited and where is virtually impossible to do here. Best advice would be to check the FSM as there are several self-tests and flow charts you can utilize to help narrow down what might need to be repaired or replaced.
It could be as simple as replacing the Radio/HVAC switch panel or it could be a more serious problem with the AV headunit.
Good luck!
Good luck!
just wondering how bad of an arc was this? usually a small arc from shorting power to ground can be tolerated and at most a fuse in the fuse box would blow if it was close enough to a component that you tapped power from. if there was a prolonged and large enough arc you may have burnt out the component itself. sometimes components such as the radio or sound amp has another fuse located on the back or inside the unit itself (depending on the make and car manufacturer). without looking and tearing stuff apart it will be difficult to diagnose here in the forum.
Crusher103
02-10-2018 08:19 PM
ScorpionGeo
12-19-2014 06:32 AM
sn4k3d
07-07-2012 06:58 PM
