Passenger Seat Switch
The bottom passenger seat switch stopped working for the slide forward position. It works fine moving the seat rearward and the upper seat switch and the power walk in function works OK. Also all the other movements like lift and tilt work. It's just the slide forward that doesn't work.
The manual is a little confusing so I am wondering if anyone has ever replaced the switch in question. Thanks, Walter
Hello the seat goes forward and rearward fine. It just won't go forward using the side switch. The upper switch and the power walk in feature also work fine. My only worry on doing the repair myself is getting the seat side finisher off to get to the switch. It has a bunch of clips etc.
