Bose frequency?
Bose frequency?
Just installed my JL Audio 10" powered sub. It has a frequency dial and gain. I am curious how low does the Bose setup in the sedan go so I can set the JL sub at that cutoff. Currently I have it around 80Hz and it sounds good. I am just wondering where I can find the information on what the system plays down to or maybe what the woofers, go down to.
Thanks.
Thanks.
I ran an RTA on mine just now. 3dB response with mono pink noise is flat full range 18Hz to 22kHz. If you want a proper, unmodified signal you can get full range from the amp input. The input is full range 2 channel front and rear. This is a speaker level signal going into the Bose amplifier.
If you are wondering what my credentials are, I recently left JL Audio as a product trainer, before that I was the Director of Sales for Nav-TV. I have been in car audio professionally over 27 years.
