For the Connected Car "CarPlay-Like" Experience
#406
MYG37.COM Sponsor
Still getting blank screen startups with my VLINE 2 in my 2013 G37 vert. Just had one this morning. It's usually 2-3 weeks between events. The only thing that fixes it is to unplug and then re-plug the connector on the VLINE2 unit.
Hey GROM:
1. Can you tell me which wire I could hook a switch into, so that I could just push a button rather than unplugging the connector each time?
2. Do you have a jumper connector that I could use in place of my VLINE2, if I want to take the car to the dealership? I would hate for the blank screen to happen while it's at the dealership. (I can just hear their cash register ringing.)
Hey GROM:
#408
Hey GROM:
Hey GROM:
#409
MYG37.COM Sponsor
Hey GROM:
Hey GROM:
#411
Got the update. Applied it this morning. Now, when I turn my temperature ****, the temperature does not display. I now have to go to one of the factory screens, then adjust the temperature with the ****, and then go back to the Vline screen. I have no idea if the blank screen startup issue is fixed or not, but this temperature thing is definitely broken now! Please advise....
#412
MYG37.COM Sponsor
Seems like Google has broken Android Auto on low res vehicles. We will try to do some workarounds, but definitely let Google know about that problem !
#413
For reference, my software versions are currently:
VCore: V20VL2.6.0.0
VBase: 88.26(L22)
#414
I have the same issue with the new version of Android Auto. It feels like the system thinks we have a widescreen when we don't. I've tried to change resolution through the developer mode in Android Auto, but that hasn't worked, yet. I'll try again when I see there's been an update.
Hopefully someone has a good answer for us as the new Android Auto works great in other cars!
#415
MYG37.COM Sponsor
#416
Hey From, I really like the VLine set up, my only complaint is the stock screen which has horrible resolution. Could you guys make an add on and have a set up similar to the "Tesla" style screen?
#417
Moderator in Moderation
Hey GROM guys, I figure you'll know the answer to this question best: the OEM backup camera (in my 2013, but I imagine all 2010+ are the same) has power, ground, shield, and then a signal wire. If the signal wire transmits composite video, like an old yellow RCA jack on a VCR, how can that get phase shifted so the colors are not correct?
#418
Has anyone tried a 3rd party modem yet?
My plan is to use this: Huawei E397u-53 with a Mint Mobile SIM card.
Using my Pixel 2XL as a mobile hotspot is getting more and more of a pain in the ***.
#419
MYG37.COM Sponsor
https://gromaudio.com/store/accessor...em-dongle.html
It works with T-Mobile plans only. Currently T-Mobile offers 2GB a month for $10, we use it all the time, works ok.
#420
You can try G-Connect that we offer:
Does it work in a "set it and forget it" mode? I assume it plugs into the actual device and IS NOT a wifi hotspot, but appears as an actual modem to the device?
