DIY 2010 G37x WITHOUT Bose Sub install
I was just wondering if anyone has found a good DIY for this yet. I STILL can't find one after all these years. Any success stories or links? Thanks.
I have the same car. This will help:
https://www.myg37.com/forums/g37-sed...b-install.html
I got the harnesses but if you do you loose your steering wheel ctrls and have to tap into your harness with 3 wires not 4 if you just tapped in the first place. Let me know if you need help.
Trying to do this as i type just found out i dont have bose....so now i need to i guess run a remote from the fuse box and mount amp need to find out where the fuses are and which fuse
RadioFlyer
04-23-2016 04:09 PM
m3clubracer
Site Feedback & Suggestions
04-11-2016 02:43 PM
