What size Mid speaker in g37 sedan? anyone upgrade before?
hey guys, im looking to do a 3-component speaker set in my 2012 g37 sedan, and i was wondering if anyone knows the mid size speaker, the one that's right near the exit handle. is it a 3" speaker?
Im looking to get some hybrid audio L3SE speakers "top of the line" and i want to make sure they fit, because if it can fit a 4" speaker then i can get a L4SE
i was also curious about this (i have a coupe) ...
if upgrading amp/speakers, how are people dealing with the mid woofer near the door handle? leaving it unconnected? most component speaker sets are just woofer + tweeter. what's the best way to incorporate a midwoofer?
I usually run a two way set up.
Three way set ups are nice but can be tricky if the installer and you have different goals.
Are you going to run the provided crossover or are you going to run an external crossover?
I currently run the LPG NFA25 tweeters. They are 2" tweeters
my audio setup is probably well above the average guy's
I have hybrid audio, very high end.
L1proR2 tweeters
L6SE mids
but im wondering if i can get some L3SE's in there, thats why i came here.
Also im running active with a MS-8 DSP.
yes thats over $2,000 in door speakers lol.
L1proR2 tweeters
L6SE mids
You should be able to get the L3's in there.
You will need to make some wood or plastic adapters.
I'm currently running an Audison Bit ten D with a Nexus 7.
Are you adding a separate amp or are you using the internal amp on the MS8?
Falker11
01-11-2016 03:22 PM
Junchao Sun
10-08-2015 12:06 PM
