Centre console and screen dead
Can you guys help me diagnose this problem. I'm out of warranty
Here is a video
Basically everything is dead, the AC is working automatically on its own, I can't control it. Screen is dead, music is dead, I thought the board was toast but it still lights up (buttons, and the clock, and airbag passenger 2 light). Looked at the back connections seem to be fine. I think what happened is buddy was installing the grom head unit, and he turned on the power (ON position) before all the connectors were back in place, because i'm getting that flashing airbag warning now too. I am hoping all he caused was a burnt fuse or two, where would I find the fuses related to the center console/display or head unit (if it exists)
Here's a pic. All is lit up. But screen is dead and no controls/buttons work, except for the hazard lights and clock adjusting, they work
![](http://s10.postimg.org/9rxqju9jd/IMG_20150810_230456.jpg)
Thanks alot!
Here is a video
Thanks alot!
LLMaximilian (05-14-2020)
The following 2 users liked this post by SS2006:
Howertot (06-03-2023),
Hey thanks. I checked, they seem fine. I assume if the fuse is closed it is working, if thats' not true, and they may be blown although they look fine, let me know
Here is the fuse diagram, not too sure which one would be responsible for the screen not turning on and buttons not working, But everything lighting up fine
I had a same problem when my audio installer tried to install my USA spec... Left battery connected and fried the circuit board. I had to purchase a brand new control panel which fixed the issue.
Piece I had to replace http://m.ebay.com/itm/10-11-12-13-INFINITI-G37-AC-HEATER-CLIMATE-CONTROL-W-AUDIO-CONTROL-PANEL-OEM-/311402439666?nav=SEARCH
The following 2 users liked this post by mj_39:
LLMaximilian (05-14-2020),
SS2006 (08-11-2015)
shoot. thanks man. I'm a bit disappointed he didn't remove the battery while doing work, but stuff happens. Was yours similarly lighting up fine, but no controls, and screen dead?
Is the screen not turning on simply because that piece above is not working? Want to ensure I don't need a new screen too, and praying the head unit isn't fried. If its just the above item that needs to be replaced, I got off easy
If memory serves me correct my head unit reacted just as yours... My installer was the one to figure out and order the new control panel. I believe both the screen/control unit work as one so if one doesn't work the other one wont either. Once he replaced the lower control unit, the screen/all buttons started to work as normal.
SS2006 (08-11-2015)
Check them all! One at a time! Audio/mirror possibly. If none are blown take it to the dealer and pay the diagnosis fee and go from there.
Did you find a solution to it? PLS HELP
The exact thing happened to me with the GROM audio. I just bought another head unit and it still didn’t fix the problem. I’ve looked at all the fuses
The following 2 users liked this post by Jonsan713:
2007 g35x sedan (10-15-2023),
Also have the same problem. Solution found?!?!?!????
Same stuff
Can’t do anything and I bet none of you intelligent idiots figured out how to fix the problem yet either, have you?
I GOT THESE CHEESEBURGERS MAN! I’ll suck your ****, man!
Thekingofknow32 (11-15-2020)
Yoooo
Did you figure it out? Please help me I’m having the same exact problem. Was your a/c stuck on full blast? I can’t figure this out on my own
Remember to check all 3
Please remember that the Calsonic Kansei AC control unit AMP (white box above the CD/Navi media unit) needs to be replaced as well.
Check fuse, AC control AMP, and Media unit. Any of those could be the culprit.
