Some Questions About Remote Start.
Hi guys , I just installed a remote start on my 2012 g37xS. There is a problem really annoying, everytime I start the car remotely and when i open the door, the engine just shut off, which means i need to start it again, this really sucks. Does anybody know how to turn off this"shut off door opened"?i just wanna open the door and driving off.
You wired it wrong, that's all I got. It should only turn off if you try to put the car in drive without "turning the car on". How those starters work is that they bypass normal ignition sequences to warm the engine but you have to get in and run the starting process in order to drive. So somewhere you wired it incorrectly for it to shut down when you open the door. Retrace your wiring
Yeah,I know, the stupid dealer broke my last remote when they repair the car, and they add this new one. They spent a whole week to install this and only one button on the remote works, which means I can only warm-up the car, no lock, no unlock and no release trunk, really sucks.
I had an aftermarket installed on my G as well and mine turns off whenever I hit the brakes after I get in. The car will stay on when I open the door, but shuts off when I push the brakes. Kinda stupid...defeats the purpose of remote start. I didn't know that would happen until after the install. The shop said it was a feature of the part. I read the descriptions in the manual and there it was, "Vehicle will shut off after brakes are depressed" Apparently its some safety feature... . Pretty annoying, I just stopped using it after a while.
I am told that with a PUSH BUTTON starter , one must restart the car before driving....It will work to start but why would you wanna waste gas like that?
*You purchased a poorly designed remote starter.
*It was not installed correctly.
I did not want another remote fob, so I bought and installed the DBALL remote start unit. It works with the factory Infiniti key fob (hit lock 3 times to start the car) and all I have to do is step on the brake to take over the car. Once it starts, I step on the brake and off I go. I don't have to restart the car, or even hit the push-to-start button.
That's not true. If that's the case, it's one of two things:
^^^this sounds like it was installed improperly too. If you can start it and just put it in gear it seems to defeat the purpose. The whole point of the remote start shutting off if you hit the brake is so god forbid someone jumps in the car before you and tries to drive off, when they hit the brake to put it in gear the car will shut down. I am not sure how the auto works for starting ...do you have to step on the brake to start it or can you just hit the button? I have a 6spd so I have to clutch it when I hit the button
With that being said, Directed removed the factory fob remote start with the latest firmware update for the DBALL and DBALL2 units. You have to purchase a new unit/model to get the factory fob remote start now. I just checked the manual for the new model and you have to hit the brake and press the PTS button to take over the car, but that's not how it was designed with the DBALL2, which is what I have, and I prefer the way mine works with the older firmware that supported the factory fob remote start.
Yeah, the normal way to start an AT you have to step on the brake and hit the PTS button. Otherwise it will just put the car into ACC mode without starting it, which I'm assuming is the same way your 6MT works if you hit the PTS button without the clutch.
JG_G37
09-19-2015 09:07 PM
gdaelemans
09-15-2015 12:20 PM
nbast
09-14-2015 12:39 PM
