Which Signal Line for DQ-61?
I'm installing an AudioControl DQ-61 in my 2008 G37S and am trying to figure out which signal wires are best to use post Bose amp for the DQ-61 inputs. I'm a bit confused by the "front door woofer" vs "front door squawker" lines. Any help is appreciated.
The "Frond Door Woofer" is the 10" driver in the front doors. The "squawker" is the smaller 3" mid range also in the door. These drivers are fed by separate wires so wiring them to separate amps is relatively easy. The tweeter poses a problem as its wired in parallel with the squawker. Check the schematics in the service manual
37
10-17-2020 11:12 AM
timc00k
02-15-2017 09:15 AM
