Bluetooth
Bluetooth
I have a 2008 G37S without navigation system. When I bought the car it came with a cable that plugs into the center console so that you can attach a smart phone or iPod to it. I currently have an Apple iPhone 4S that I use to plug into the phone and am able to play music through the stereo. I am considering going to the iPhone 5S but that phone has a smaller plug which the existing cable will not fit. I went to a local Apple store to inquire if they had a similar cable that would be adaptable to the 5S. They said that they did not but indicated that since my phone is paired with the car that it may be possible to play music through the system wirelessly without having to plug the phone into this cable. Does anyone know if this is possible and if yes how would I go about doing this? Is this feature available for both the 4S and 5S?
Any guidance will be appreciated. Thanks
Thanks. Where can I buy one of these adapters? Reason I ask is that I had gone to the apple store and they said their adapter will not work. Does Infiniti make a similar cable that will plug into the console and will be able to plug the other end in the smaller hole of the iPhone 5S?
Great. Thanks
I have a 08 g37s and I got bluetooth to play music now and have the hands free also working. Just follow the instruction and connect them as he says in the post and it'll work!
Here's the guide that I followed:
https://www.myg37.com/forums/audio-v...ml#post3809955
Thanks to Jestered.
Thanks to Jestered.
Thanks to Jestered.
Thanks to Jestered.
cheapest and best way to go bluetooth music. sound is as good with this as with the 30 pin connection. single unit sits in the armrest compartment and connects automatically to your phone. factory bluetooth phone function over rides the kinivo unit for calls. since it sits in the armrest, i use the phone/siri to initiate and control all playlists.
Amazon.com: Kinivo BTC450 Bluetooth Hands-Free Car Kit for Cars with Aux Input Jack (3.5 mm) - supports aptX: Electronics
http://www.amazon.com/gp/aw/d/B000I2...110_SY165_QL70
Sorry, 3.5 plug to rca connector needed for the g.
