Blown mid on Bose system suitable replacement?
Hey guys so I think I blew the mid on my passenger door in my coupe based on the rattle it's making. Looking to see what you guys recomend as a suitable replacement? It is the Bose system. I understand that we have a 2ohm system but would I be wrong in thinking that a 4 ohm speaker would be ok to put in there since the amp would only have to work half as hard to power it. Or is the system more complicated than that?
Are you talking about the 10" in the door? The 3" tweet/mid by the door handle? Or do you have a three way set up?
A 4 ohm driver will work. A lot of factors come into play when talking about speakers. a 4ohm speaker with high efficency will be "louder" than a 2 ohm driver with low efficency on the same amp.
you have a lot of options if you use this
PVC Speaker Adapters - CNC Machined - In Stock or Custom Made
Any 2 ohm,4 ohm, 6 ohm, 8 ohm, or even 12 and 16 ohm will work.
Find a high efficiency tweeter/mid to fit in there.
The problem you might run into is that the new tweeter will probably sound way better than the Bose tweeter. That may or may not be an issue you will have to deal with.
Kris 3.7 (09-17-2014)
It won't fry the amp, I ran some ScanSpeak Discovery drivers in the doors for over a month with the standard Bose amp. That was back in my naive days when I thought a simple speaker upgrade would help that sorry sack of Bose crap. There will be some serious imbalances though as others have said. Speaker impedance, frequency response and efficiency are going to make it sonically obvious that "one of these things isn't like the others. Sorry I don't have my original speakers from the doors or Id send you a replacement
if they say they are working in the description they should work.
If they dont, make an ebay claim and get your money back.
I've never had an issue with a seller that has more than 200 ish positive feedback
