Any Recommendations for Battery Charger/Maintainer?
I currently have always had this hooked up to the car. I bought it at Walmart over 5 Years ago
SEM-1562A:
Realized after reading reviews and reading online it seems what I have is only a maintainer and has never been able to charge my battery as it was made for smaller batteries, but when I look at 3 AMP chargers/maintainers some people say you dont need that.
Most Google searches and forum searches lead results to outdated reviews and there is much more newer stuff out in the market.
I just want to know is there newer ones out in 2014 or any current ones people recommend?
I saw a CTEK one which looked great and is used by Porsches and other high end cars but my car tends to sit around a lot so I want a charger that can charge the battery when Voltage goes too low, along with maintaining a charge and also I have read many dont have desulfator mode.
So should I just grab the battery tender jr or plus from walmart or should I goto Kragen, Oreilys, autozone and look around or should I look for the CTEK online?
SEM-1562A:
What exactly do Gel Battery's do? And what If it ends up dying like my normal one has, does the life go bad?
My car sometimes sits really long before I even go start her.
Ok I went ahead and bought the Battery Tender Plus, Can someone give me some information about buying a Optima Yellow Top, I am thinking of getting one, The guy at audio shop said I dont need one, but I am guessing it holds a charge better than a regular battery and lets me play music and use navigation and etc without having the Ignition turned over, but how safe is that?
I was thinking if I get a Optima Than I can throw the current one in the rear, or should I throw the Optima in the rear with the Audio System and have it Isolated with the Current Battery.
Doesnt make sense to waste the current one.
On the optima yellow top its a deep cycle / dry cell battery therefore, in case you completely kill the battery you can jump start it again and it will be ready to go.
I also have a Old Optima Yellow Top that was hooked up to the Audio system in the trunk but has under 2 Volts and was made in 2007, I dont think it can be revived
dedmanchan
09-24-2015 11:25 PM
