Finished my Sub/Amp Install... Finally.
Old 05-13-2014 | 10:20 AM
Paratrooper's Avatar
Paratrooper
Can I do this on my non-Bose setup..?
Old 05-13-2014 | 11:14 AM
blazeplacid's Avatar
blazeplacid
Yes
seach my username for a post that has the diagrams for bose and non bose set ups
Paratrooper (05-13-2014)
Old 05-15-2014 | 09:21 PM
vuedoo's Avatar
vuedoo
To op: how long did it take to get the custom sub enclosure from the seller? Their ad does not mention this. Though I assume its made to order. Thanks
Old 05-16-2014 | 12:48 AM
gsteigerwald's Avatar
gsteigerwald
It took me about 2-3 weeks to get it. It doesn't help that I'm in Philly area and the seller is in Washington so if you are closer it will be quicker
vuedoo (05-16-2014)
Old 05-17-2014 | 01:20 PM
Romeo0119's Avatar
Romeo0119
How does it sound? It's fiberglass? I have a zen enclosure now with 1 10" and I'm thinking about changing my set to a single 12
Old 05-17-2014 | 02:15 PM
gsteigerwald
Yes, its fiberglass. It sounds amazing, hits like a champ. There's no rattling at all besides my interior LED map lights that came loose from the double sided tape because it was hitting so hard. I highly recommend this box from them.
Old 05-18-2014 | 11:58 PM
Romeo0119's Avatar
Romeo0119
So what did you mount your amp to? I saw your set up pic and I know that side is just metal cover my thin carpet. Did you just use some self tapping screw and mount it straight to the metal?
Old 05-19-2014 | 08:59 AM
gsteigerwald
Yep I just used 2 self tapping screws into the right side of the amp into that metal piece and didn't use any screws on the left. Those two in the right is holding it up just fine for me. I didn't want to put too many hold into that side carpeting so I just did those 2.
Old 05-19-2014 | 10:28 AM
Romeo0119's Avatar
Romeo0119
Oh I see, I hate to use those screw, I just don't know if there any wires behind that metal, scare to screw into them. But I guess there aren't any there if u did yours like that
Old 05-19-2014 | 10:31 AM
gsteigerwald
Yep no wires at all there, nothing to worry about.
Old 05-30-2014 | 01:27 PM
EricG37-nvs's Avatar
EricG37-nvs
is that a 10" or 12" sub enclosure gsteigerwald? Thanks
Old 05-30-2014 | 01:34 PM
gsteigerwald
Its a 12' Alpine Type-R the Dual 4 Ohm sub but I wired it to 2 ohm
Old 05-31-2014 | 03:14 AM
RA081224's Avatar
RA081224
Originally Posted by 08Gsmith25
is the factory signal not a good one? i have seen several people using LOCs
The signal from the factory head unit (BOSE flavor) is essentially line level and is pretty darn clean for a factory unit. You could do better but only at the expense of the added pain of replacing the head unit. When replacing the BOSE sub or main amps, LOC's are not required
Old 06-13-2014 | 04:01 PM
  #29
out0focus's Avatar
out0focus
I wish I had this thread when I installed my sub I have an LOC in mine and I knew it sounded weird. I need to do some re-wiring this weekend.
Old 06-25-2014 | 05:09 PM
  #30
GS07's Avatar
GS07
I am about to perform a similar installation in my new 2011 coupe. Based on the location that you mounted your amp; where did you terminate your ground wire? I have seen some terminate to a bolt near the bottom of the seats but I am trying to abide by the factory recommended <30" ground wire distance. Nice install BTW!!
