HIDEAWAY Install - Power Cable to Battery Question
Old 04-03-2014 | 01:34 PM
OLPEMI's Avatar
OLPEMI
Hello,
I am purchased a Kicker Hideaway powered amp and reviewed the installation guide and have a question.
The attached picture shows the cable end that needs to be connected to the battery and I am wondering how I can do that.
When I searched the forum for DIY, the others have inserted the power cable from the engine bay to the passenger glove cabinet area.
However, for this wire, I don't think I can do it like the DIY and asking for help!
I also attached the installation guide from Kicker.
(I do need to splice a part with a fuse by the end of the cable, but it is still same concept)
This is my first audio part install, Please help!
Attached Thumbnails HIDEAWAY Install - Power Cable to Battery Question-20140403_110947_resized.jpg   HIDEAWAY Install - Power Cable to Battery Question-hideaway.png
Old 04-03-2014 | 05:07 PM
blazeplacid's Avatar
blazeplacid
you need ring terminals and a fuse.
**Please do not install this with out a fuse**
find one that will fit that size wire (looks like 12-10ga)
run the wire into the cab though the large rubber gromet behind the battery.
Its probably 4-6" around.
Cut a hole in the grommet.
Removed the glove box and interior carpet/panels around the area.
Run power wire to the rear of the car.
Old 04-10-2014 | 07:23 PM
RA081224's Avatar
RA081224
Originally Posted by OLPEMI
Hello,
Check out this article on a sister site. Its got some nice pictures. Even though your wire is about 1/20th the size, Id route it the same way
Sub install for 2009 G37 sedan : G35 and G37 Interior, Exterior and Audio
Old 08-29-2019 | 10:40 PM
Tstow's Avatar
Tstow
Lightbulb Anyone? - Kicker Hideaway 11HS8 in 08 G37 Coupe?
Has anyone installed the Kicker Hideaway in their G37?
I saw this thread and another similar but no one has posted how they did it, where they mounted it, or how it sounds once installed.
please help?
anyone have a video on it?
thank you.
mydogthecow
05-27-2018 02:27 PM
Fantality4
04-26-2018 01:28 AM
tattoo400
03-18-2018 01:56 PM
Jabayon
General Tech Questions
12-14-2016 02:37 AM
Dough1397
09-22-2016 12:52 PM
