G37 Sedan Non-Bose Speaker Size?
I was wondering what size is the speakers in front and rear? The tweeters as well and is there anyway to put a double din or single din radio in the car?
I didn't want to start removing stuff and order it. I am sure someone has change their speakers on a G37 Sedan non bose before.
Thanks in advance
Thanks in advance
fronts are 6.75".
You can use the speaker adapters from a G35 in the front doors.
if you get the adapters you can run a 5.25" if you want or up to a 7" if the cutout is small enough.
rears are 6.5"
no way to install another radio easily. With heavy modding anything is possible
look into a sound processor
rears are 6.5"
fronts are 6.75".
rears are 6.5"
rears are 6.5"
I'm pretty sure they're all 6.5" in size ? Tweeters are 2" I think. The adapters that came with the aftermarket speakers couldn't fit on the car. So I bought some speakers and tweeters adapters from www.car-speaker-adapters.com. Exactly the same shape as factory ones.
I honestly cant remember the rears size
I disconnected them and that was it. Left them in place.
It only takes a second to pop the rear door panel off
JakeG37
08-03-2015 09:28 PM
