Big 3 problem please help
I did a big 3 aka upgraded grounds on my car for a system I'm starting and now when the car is idle it feels like the car wants to stall, I was told that's normal when you disconnect the battery and the car needs to learn all over again. Can anyone clarify this? Upgrade included:
-Negative on battery to frame
- negative on battery to engine block
- positive on battery to positive on alt
did you leave all of the original wires and harness in place?
ensure all the wires are tightened
if all else... remove the wires one by one (turn car off...remove one wire...turn car back on)
FlyIce
09-29-2015 04:07 AM
Murkr
09-28-2015 10:45 AM
