Question re if installer made mistake
A month or so ago I had a RF P300/10 powered sub installed. He said that he tapped into wiring in the trunk. Having spent hours searching these forums on different audio issues I realize that he could've tapped into multiple places but at the time I didn't know enough to ask where and I doubt the guy would even remember the install. It was a bad experience to say the least. I recently discovered after a heavy rain that he drilled improperly through the firewall and the result was significant rain leaking into my driver side floorboard.
But I also recently discovered last week that my right rear "woofer" isn't working at all. My question is - is this a usual result of tapping into some wiring in the trunk or was this also a mistake?
Thanks
Thanks
Thanks. I realize I wasn't clear. I know the drilling was a mistake but I am wondering if it is normal for a rear woofer to no longer work if wires are tapped into in the trunk area.
