Help iOS 7 Problem? iPhone not recognized.
Old 09-23-2013 | 01:01 PM
Kuz's Avatar
Kuz
Question iOS 7 Problem? iPhone not recognized.
Recently upgraded to iOS 7 on my iPhone 4s, and since then my '08 G wont recognize the phone, saying that it is not recognized. Is anyone else having this issue?! If so, have you resolved it?
I used my phone to listen to Spotify. This is really driving me insane.
Old 09-23-2013 | 03:32 PM
telcoman's Avatar
telcoman
Yes I had a problem but it was hardware related. Took the 4S to the Apple Store and they replaced it
Did you do a back up of your 4S prior to upgrading to OS 7
Is your bluetooth turned on on your IPhone?
Telcoman
Old 09-23-2013 | 07:33 PM
sharkman's Avatar
sharkman
I had the same thing happen... On the phone, I went to "Bluetooth" found the entry for the name of my phone that I had assigned when I first set it up and clicked it while in the car. It went through and found the phone and connected..
sharkman
Old 09-24-2013 | 12:18 AM
Upgraded. No issue with my 08 at all, recognized it exactly like before.
Old 09-24-2013 | 12:22 PM
mguentz's Avatar
mguentz
Ever since I updated my 4s to iOS7, it's been difficult to maintain a connection via the USB cable. I get the "No USB Memory" error and "Check Device Connection" error unless the connection to the iPhone is just so. This wasn't a problem prior to the upgrade...could be a coincidence, but it seems weird.
Old 09-25-2013 | 05:54 PM
telcoman's Avatar
telcoman
Try getting rid of the cable and connect/pair via bluetooth
Telcoman
Old 10-09-2013 | 03:03 AM
TripleJ's Avatar
TripleJ
I have a 2010 g37x coupe, works perfect via USB and Bluetooth with my iPhone 5s.
Old 10-15-2013 | 12:02 AM
handsome_rob's Avatar
handsome_rob
09 g37
my 3gs worked fine full function
my work 4s worked before I upgraded to ios7, after the next track on the wheel and head unit didn't work.
bought a 5s with 30 pin to lightning converter, same problem.
next track buttons only seem to work on older software (tried the 3gs again to see if the buttons were broken, 3gs worked fine)
Anyone know a way to fix this, if possible?
delfinparis
10-08-2015 07:06 PM
butwhatuptho
10-04-2015 08:51 PM
Awgd8
09-30-2015 07:22 PM
MrRiv
09-29-2015 05:59 PM
k19g37x
09-29-2015 03:46 PM
