FM Modulator
FM Modulator
Hi Everyone,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I just picked up a CPO 2010 G37Xs recently. It’s a huge upgrade from the 99 Saturn I was driving . One issue I am having is the inability to put Sirius in my car. As a subscriber I was hoping to be able to buy the same or similar box I bought for my wife's Murano, install it in the trunk and be on my way. Apparently that is not the case with 2010+ g's. Instead I am relegated to using my Sportster Replay that I had in the previous car. Before trading in my previous car I took out the FM modulator that I installed to suppress the fm signals around me and provide clear the signal being transmitted from the Sirius unit. This weekend I took apart the center console in an attempt to install the same modulator but my time was wasted as the FM antenna plug was not the same. I also took a look at the FM amp that is installed in the LH aft pillar but the connector there was different as well. Can anyone recommend what I can do to get a clearer sound since we do not have an AUX input? Do they make a specific modulator we should use? I have seen this but I have an Android phone :<o></o>
Neo Car Audio The leader in OEM integration.
Bluetooth over my phone isn’t an option as my 3g/4g reception is spotty (Thank you Sprint)<o></o>
<o></o>
<o></o>
The 2010s came with XM.
Since XM and siruis merged and are pretty close to the same...why not use XM?
If you have a lifetime subscription, try calling and see if they will switch it.
Chris Olson
03-28-2024 09:46 AM
Diode Dynamics
Lighting/Cleaning Products
81
11-30-2021 02:28 PM
timc00k
02-15-2017 09:15 AM
r0cketm0nkey
General Tech Questions
17
11-23-2015 03:34 AM
