USB stick for audio
Old 05-14-2013 | 08:03 AM
Snaoum's Avatar
Snaoum
USB stick for audio
2011 G37xS with navi. Can I plug a usb stick with music and movies and be able to play and control it from the radio? I haven't taken delivery of my car yet, few more days but trying to get info ahead of time.
Old 05-14-2013 | 10:53 AM
blazeplacid's Avatar
blazeplacid
no, you cant play movies
Flac files also do not work
some WMA files do work
MP3 files up to 320kbps work fine for me
Old 05-19-2013 | 11:26 AM
IZZY D's Avatar
IZZY D
yes audio files only. and I recommend getting a mini USB so things don't snag it while plugged into the console.
I just got this one for under $20
Old 05-19-2013 | 12:44 PM
AntonsG25x's Avatar
AntonsG25x
I just got a 2012 G25x, can i plug a hard drive right into the usb port, can it contain other files other then audio?
Old 05-19-2013 | 12:50 PM
IZZY D's Avatar
IZZY D
I think there is a limit on the # of audio files the radio will recognize. At least in my Camaro there is a limit of around 2500. so a external hard drive is probably overkill.
Since there is no music box on my 2013 I am going to start throwing everything on these mini USBs
Old 05-19-2013 | 02:02 PM
AntonsG25x's Avatar
AntonsG25x
any pointers how to set up the folders, ive been trying different combos on my jump drive to test it out and it only reads what ever the first folder is. Also says lot of the files are unplayable? any ideas? thanks!
Old 05-19-2013 | 02:03 PM
AntonsG25x's Avatar
AntonsG25x
also i do not have the nav just the basic audio system
Old 05-20-2013 | 09:13 PM
IZZY D's Avatar
IZZY D
I just went old school putting mp3 or WAV files on the USB drive.
I put the drive in my computer opened libraries(windows 8) opened my music and then copied/pasted all the artists I wanted to drive D (the usb drive) The G has Nav so it displays the folders by albums(not the artists like I copied) and several options for playback, ie: 1 folder, All, Random.
On my Camaro (no Nav) I have to use the select/ menu buttons on the radio to do the same thing but it shows in the display essentially the same stuff. Random, repeat artist Etc. Tune **** scrolls through song lists etc. I would think the Non Nav G series would behave similar.
I am still playing with the G only 800 miles on it and still getting familiar with the radio (without Musicbox ).
anyway this way works on both vehicles.
You may have to format the USB to remove all the excess crapola that comes on them from the manufacturer. I don't know if it makes a difference, I just format them out of habit.
Below is the screen on Windows 8 I used, older windows versions are similar.
I hope this helps.
File Type: jpg
Old 08-26-2013 | 10:13 PM
Eric M's Avatar
Eric M
this does not answer my question
delfinparis
10-08-2015 06:06 PM
parkern
10-01-2015 10:15 PM
pal51961
09-27-2015 08:38 PM
4DRZ
Intake and Exhaust
09-24-2015 09:25 AM
sharmelan
09-23-2015 11:48 AM
Quick Reply: USB stick for audio
