temporarily disabling stability control?
Had my G37 about two months now. THis is my first car with stability control. I grew up on rear wheel drive cars, including my dad's '84 Corvette, so I have no problem at all coping with oversteer. But of course I can't really explore that with the G37, since the stability control works to prevent it before I ever get a chance to take action.
There's a dashboard switch to disable traction control, but not for stability control. However, a friend has suggested that there may be a way to temporarily disable stability control through some arcane sequence of control inputs. I'd like to be able to do this so I can go find a parking lot and see how the car behaves when the back end steps out, i.e. what combinations of turn and throttle are required to initiate oversteer, how rapidly/suddenly the back end steps out, and how difficult/easy it is to correct the situation. I want to get to know my G37.
So is my friend right? is there some super-top-secret way to temporarily disable stability control?
VDC stands for Vehicle Dynamic Control. this includes Traction control along with whatever other countermeasures it does. the light will still flash SLIP, however there arent any countermeasures in effect with the system switched off. As far as i know the only thing that regulates "Stability" is the system cutting throttle and adding braking to the back wheels when it senses a slip.
onthefence (05-02-2013)
To the OP's point, if you want to power into a 90* turn with controlled oversteer, then you want the TC off, otherwise the car slaps you back and says, "No soup for you" in no uncertain terms. I've done that on more than one occasion, and it's pretty embarrassing. Ditto if you want to launch as hard as possible out of the hole. Basically, TC is great when you need it, but sucks when you don't... which is most of the time.
I'll tell you what really sucks... hitting the trunk-release button when you're reaching for the TC switch. Somebody really didn't think that one through well.
As for reaching to the TC switch while in motion... it's still a panic moment when you realize your finger isn't where it's supposed to be. Kind of ruins the mood, if you know what I mean.
(wait for it)
That's true. However, if you're at a full stop, the trunk will still open. Nothing says "Idiot" like popping the trunk when you want to launch the car.
(wait for it)
(wait for it)
I thought popping the trunk is part of the luanch control procedure, no?
AFAIK, Active Brake Limited Slip is an AWD, automatic transmission thing. RWD Sport-package G's get a proper Limited Slip rear differential. (Well, proper-ish, in that it's VLSD.) And Journey non-Sports are out of luck.
I'm generally a big fan of RTFM, and it looks like I need to take my own advice. You're right, the manual does explicitly say that VDC manages traction control, simulated limited-slip diff, and stability (oversteer/understeer). It goes on to say:
Originally Posted by G Owner's Manual
When the VDC switch is used to turn off the system, the VDC system still operates to prevent one drive wheel from slipping by transferring power to a non slipping drive wheel. THe VDC warning light flashes if this occurs. All other VDC functions are off, and the VDC warning light will not flash.
If the car would automatically correct for oversteer by steering into the skid instead of hitting the brakes or chopping the throttle, I think that would be a lot more interesting.
Are you saying stability management is definitely still active, and that even with the VDC switch pressed, I will not be able to do powerslides or donuts?
There's this 4 block dirt road by my house that they oil on a regular basis, and at the transition to pavement, there's a stop light that I always turn left at. I love to turn off the traction control and gun it around that corner. Takes no effort to kick the back end out and sail through the corner because of all the oil on the pavement. Must have traction controll off, of course. It's great with the AWD because the aѕѕ end flies out, and the front wheels pull you through the corner. Drives me nuts that sometimes I forget the traction control will kick in. Even worse, you can't turn off traction control while the system is actively controlling traction (light flashing), lol.
My G35, I disabled VDC because I HATED how I want to accelerate, yet the stupid computer wants to power me down.
Not fun when trying to move fast in heavy fast traffic!
G35, I just unplugged the sensor under the center console. I assume we can do the same in the G37?
m3clubracer
09-20-2015 09:20 PM
