XM radio reception
#32
I took a stab and bought a new cheap-o antenna from amazon
Took about an hour and a half including dropping the headliner to try grab the connector at the antenna (different fitting unfortunately). Worked right away and no issues on my N/S roads that it would completely drop on (look at a map of phoenix, it is literally half the roads run directly N/S).
I put my new antenna next to the 3rd brake light on the rear shelf. Hope it helps out someone else with this issue.
Amazon.com : Terk by Audiovox XMICRO2 XM Mini Roof Mount Antenna : Vehicle Satellite Radio Accessories : Electronics
#33
I took a stab and bought a new cheap-o antenna from amazon Amazon.com : Terk by Audiovox XMICRO2 XM Mini Roof Mount Antenna : Vehicle Satellite Radio Accessories : Electronics
I dont have a bose system its a base audio. I don't think mines in the headliner. I just bought the antenna planning to do it tomorrow or so.
#34
Same issue with XM.
I have been having the same issue with XM reception. I frequently get loss of signal, loading, and more frequently (except when dealer looks at it) where the car goes under an overpass, drive-thru or on start up, the satellite radio is back on XM1.
I think I have the Bose system (speakers on back deck and dash have Bose on them) and I have what looks like option 1 in Mich37's picture in the first page.
Anyone add one of the antenna boosters he used? If so, how'd it work out, and how did you splice it inline? Thanks!
#35
Have you tried installing that signal booster or another antenna yet? If you did, what connectors did you use to plug into the factory antenna connection?
#36
I have nav and the connector is in the dash. The base is in the trunk and pretty easy to get at. Pull down the trim under the deck and look for the pink plug.
#37
A bump, and what I did
First post for me on this forum:
Thanks for the great thread. I wanted to bump this and provide some insight as I had a problem with my satellite reception and the info got me most of the way. This thread really helped me get started figuring out what my satellite radio issues were. I have the 2012 with no-nave (so the satellite receiver is in the trunk). Turns out the antenna was bad. I had great reception in certain places, and horrible reception in others (including wide-open, unobstructed spaces).
The first thing I did was track down and order the Terk 18db in-line amplifier. Snagged that from Amazon.
Since it comes F-connection female, I need to buy TWO(2) Male-to-Male F adapters (Coax male-to-male) in RG6. I grabbed these from RadioShack.
At first I had purchased a Female F-type to SMB-Female adapter and a Female F-Type to SMB-Male adapter.
The problem was the amplifier and all these adapters are too bulky (Think FAT Permanent marker) and doesn't sit well in the space the receiver is in. The other problem was that MY antenna is broken, so this configuration DID NOT FIX my problem. It may work for some if your antenna isn't broken and this would be the end of your project.
What I ended up trying was the following in the order of connection:
I ran the satellite cable from the trunk deck inside the car (needs to be as close to the window as possible without touching it), through the car-seat anchor point on the deck, and to the receiver. A little Velcro to keep the antenna from bouncing around the top of the deck, and I have CRYSTAL CLEAR Satellite radio.
I hope this helps anyone that needed to go a few more steps past amplifier.
The cable is 20', not 6" like the picture would have you think.
#38
Anyone with reception issues can improve it by installing a Terk XMAMP18 in line signal amp. I was having issues where the signal would cut in and out in areas where tall trees bordered the road. My BMW never cuts out in the same areas so I know there must be a way to improve it. Since I couldn't find an in line signal amp for automotive purposes I bought one for home applications. The input and output are RG6 female connectors on the terk amp, I cut the cars antenna line and spliced 2 male ends in so that I can just thread it in easily. Voila never drop signal anymore unless I'm in the garage. Bought mine on ebay for $20 bucks, worth every penny.
#40
I'm guessing I have config #2 above? I have a 2012 G37x Sport with NAV. Anyone know where the satellite antenna is on mine and can point me to a drawing so I know where to replace the antenna?
abravenewworld
07-25-2021 01:46 PM
