09 g37s - Bluetooth doesn't always connect
Old 04-15-2013 | 07:46 PM
Gopennst8's Avatar
Gopennst8
Purchased my car about 2 months ago and successfully paired it to my iPhone 4 via Bluetooth. Problem is that it doesn't always connect to my phone when I get in the car. Sometimes I have to go into settings -> Bluetooth on my phone and it will pair up. Then it seems like it automatically connects the next several times I get in the car. But then randomly will stop doing it until I force it to connect again.
Any thoughts? Thanks!
Old 04-18-2013 | 09:00 AM
Jimmah's Avatar
Jimmah
I have the same problem and have not been able to figure it out either. Very interested for a response here as well
Old 04-18-2013 | 11:23 AM
Redpit's Avatar
Redpit
I ,unfortunately, do not have a solution for you, but I can tell you the same thing happened to me. I upgraded to an iPhone 5 and now it pairs every single time without issue. Obviously there is some kind of conflict between the iPhone 4 and the car. Sorry I couldn't be any more help just wanted to let you know it seems to be a phone issue and not a car issue.
Old 04-18-2013 | 11:39 AM
Fezzik's Avatar
Fezzik
what firmware are you on with your iphone. Also sometime there could be updates to the car's bluetooth firmware that may help.
Old 04-18-2013 | 12:41 PM
Jimmah's Avatar
Jimmah
My phone's IOS is up to date but the car's on the other hand maybe another story. How do you go about updating that. Not trying to jack your thread Gopennst8. I sit at a computer almost all day so always trolling
Old 04-21-2013 | 10:54 PM
bresbones's Avatar
bresbones
this has been a problem for most..my iphone 4 worked fine on '10 g37 but had problems when i got the iphone 5, specifically disconnecting all incoming calls..after a recent iphone update it seems to have fixed the problem. my suggestion would be to delete the phone on the car's bluetooth settings as well as going into the phone' bluetooth settings/devices and press on "forget this device".. do a hard reboot on your iphone then pair the phone again to your car and hopefully this should solve your problem..
Lt8Che
91
04-08-2022 04:55 PM
Thedbarz
33
02-09-2016 12:05 AM
JoshB
10-15-2015 03:08 PM
joeposter
09-08-2015 04:36 PM
goredcar
08-04-2015 09:03 PM
Quick Reply: 09 g37s - Bluetooth doesn't always connect
