08 g37s coupe screen/radio/ac problems
Hey, just like the title says. My screen does not turn on and my sounds does not work at all and my ac is on full blast but I have no control of it. Looked at the airings behind the center console and everything and the wiring looks fine... Is there anywhere else I can look to fix this problem or how I can fix the problem?
08 g37s display problems
I got a 08 g37s coupe 5AT with navigation having problems with display stop coming on it started with a 5 minutes delay once u start the car then got longer now it wont come on at all and solution.
First start with fuses. Just check them to be sure. It may mean incurring a cost of $5 versus $200 or more.
Honestly, (if I remember correctly) I think it's an electrical issue with a circuit board that controls both the radio and climate control. It's located in the back of the radio/heater unit.
This was an issue with G35's and I thought Infiniti corrected it, but it sounds like the exact same fried circuit problem they were having earlier.
Hope this helps
Hope this helps
Yeah i got a 08 g37s coupe auto and having the same problem I switched out the display from a salvage car but no help infiniti is saying that displays is $1600 which I don't want pay plus I don't think it's the display cause like i said i got one out a salvage car for $150.
Chris Olson
03-28-2024 09:46 AM
maybeg37
09-08-2015 02:33 PM
