LCD Connector help
LCD Connector help
I am looking into the possibility of relocating my stock LCD screen and replacing it with a larger touch screen with a custom bezel but I don't want to splice into the stock wiring harness. The only place I can find the connector is through alibaba.com but I really don't want to order 10,000 of them (the minimum order). Does anybody know where I can get one?
Group buy time!!!
You know, this will make for an EPIC group buy.
Are you talking about this connector? I've been looking for it too. I think it's not off the shelf. I would recommend in this case you cut and extend it. Put a 37 pin D-sub connector on either end so you can restore it to the original position if you change your mind. Nobody will know it's been cut but you.
i just posted about this as well, i want to relocate the screen out of the way to leave room for an ipad or tablet install ( to look stock). have not found connectors either but ive considered splicing a few feet of wire into the harness to allow the screen to be mounted somewhere like the sunglass holder or something custom.
Diode Dynamics
Lighting/Cleaning Products
81
11-30-2021 03:28 PM
aktif8
05-23-2016 12:56 PM
delfinparis
10-08-2015 07:06 PM
