Flickering headlight. Not bulb. Fuse? Ballast?
I'm having this problem as well.
I'll take it to dealer to check ballast before buying replacement bulbs.
My issue started slow with the just one light flickering off.
Now the passenger side is completely off and the driver side flickers off.
I had this issue when I was using some generic HID bulbs. Once I switched them out to Osram CBI bulbs they turn on everytime. Try putting your stock bulbs in and see if you still have the issue.
Just wondering if you ever found out what the problem was?
mahadeod
10-06-2015 02:02 PM
