G37 Sedan Bose Components?
Im researching replacement component speakers and wanted to know what has been used to replace the factory speakers.
I would like to go the 3 way route being that is already available via the original factory design.
I currently have a 12w3 in a sealed box, being fed by an Alpine PDX-V9 which hits great but the balance with the sub and the re-amplified factory fronts is just not there.
I primarily listen to hip hop so the mid bass on the component will have to be able to handle more usage than those that are into Easy Listening which I enjoy from time to time as well but not as often.
Any feedback that you guys have will be appreciated.
i have a set of morel elate 9 which fit with a little modification. the midbass is nine inches which you will have to fabricate a bracket for. it also has a 3.5 inch midrange which fits perfectly in the stock location. the tweeter also fits in the stock location. for a good picture of how it looks here's a thread that i've been following Charliekwin's 2007 G35 Sedan build log - DIYMA Car Audio Forum
p.s. you're using the same amp that i have and i've been looking at the 12w3 to replace an older diamond sub that i'm also using in a sealed box. did you think that the 12w6 was overkill for your setup? i really don't know that much about matching components.
i actually bought them from an authorized dealer four years ago for my g35 for $1500. the reason that i got such a good deal because i let them do my install also. every authorized dealer that i've seen lately has them listed over 2 grand but that might be because morel has upgraded the elate series.
Chris Olson
03-28-2024 09:46 AM
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
connoisseurr
01-13-2017 12:52 PM
