what after market stuff can I get done do improve Bose sound.
Old 01-21-2014 | 02:29 PM
STEVEKID98's Avatar
STEVEKID98
From: i live on the jersey shore,poconos pa, and missiauga canada
I did the same thing with jl c5 all around ,and 10 w6.this thing hits so hard it takes your breath.I also installed the 1200 in line kinetic battery.jl audio hd amps with the clean sweep.
Old 01-22-2014 | 12:39 AM
lamanite's Avatar
lamanite
how much did you end up spending for this setup?
Old 01-22-2014 | 11:33 AM
ai3j50's Avatar
ai3j50
Does anybody know which speaker wire adapters we need for the Bose system?
Will these work on the Bose connectors? http://www.ebay.com/itm/NISSAN-INFINITI-2004-UP-Speaker-Harness-Adapter-Connector-/251334771519?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AInfiniti&hash=item3a84b8433f&vxp=mtr
Old 01-24-2014 | 12:42 AM
JoeBro788's Avatar
JoeBro788
which coupe models have the AV jacks? And where are they located??
Old 01-24-2014 | 02:02 PM
Jack10525's Avatar
Jack10525
Wouldn't dynamat help the sound quality?
Old 01-24-2014 | 03:11 PM
pebkac's Avatar
pebkac
Audio control LC2i 2-channel line output converter for adding amps to your factory system is all that's needed for adding a Sub with your aftermarket amp...
Will these work on the Bose connectors? Nissan Infiniti 2004 Up Speaker Harness Adapter Connector | eBay
Old 01-25-2014 | 12:26 AM
Darth Kinetic's Avatar
Darth Kinetic
Subscribed.
Old 01-25-2014 | 10:56 AM
monytx's Avatar
monytx
Think of Dynamat as insulation. It's gonna stop all the unnecessary rattling.
Old 02-02-2014 | 04:46 AM
RA081224's Avatar
RA081224
Originally Posted by hamkha1ebay
so I have a g37 coupe and I feel like its not loud enough when the windows are down or when i'm just steady cruising. what can I get to it? or get something done from ABT or best buy?? any help or advise will be great.
How loud you want depends on how much $ you want to spend; also, do you want clean sound or just sound? Before you set out on your quest, decide how much your budget is and that will tell you how deep you can go. As others have said, the amp/sub combo is probably the easiest. A single 10 will drown out the Bose system so thats all thats really necessary. However, as most of the owners around here have discovered, I'm betting once you start upgrading, your not going to be satisfied until you gut the entire Bose system.
Old 02-02-2014 | 04:49 AM
RA081224's Avatar
RA081224
Not really necessary. The signals from the head unit on the Bose SOW system are essentially line level. Most quality amps have input signal sensitivity adjustments to cover any differences.
Rybitron
11-18-2015 04:11 PM
Dillybar12
11-01-2015 08:23 PM
parkern
10-01-2015 11:15 PM
Irishcurtis
09-30-2015 12:39 PM
VIVID
09-29-2015 11:58 AM
