Bluetooth
Bluetooth
I have a 2008 G37S without Nav. My bluetooth has always worked fine except a few days ago, it began doing peculiar things which I'll explain. When I get in the car with my Verizon blackberry and start the motor, the monitor in the car starts indicating that a call is in progress which is not the case. I will glance down at the phone and there is no call taking place, yet the car monitor still shows a call being made. I try to hang the phone using the button on the steering wheel to no avail. I have to hit the other button on the steering wheel as if I'm trying to make a call and hang up with the other button on the steering wheel. I have to do this a number of times before the monitor returns to normal. I can accept incoming calls, but I also noticed that I cannot make outgoing calls using the voice feature. When I initiate the voice feature it asks to state the first 3 numbers, followed by the next 3 numbers, and lastly the last 4 numbers. When I say "dial" it doesn't dial but merely appears to hang up. I even deleted the phone from the system and re-paired it hoping that would correct it but it didn't.
Has anyone ever experienced this? I will be taking it to the dealer but because its out of warranty I fear what the charges may be.
Thanks
Thanks
Yes I did as I stated above. I do have an update though which proved to be an easy fix. I checked with one of the IT guys at work and he told me to remove the battery from the BB and reinsert. I didn't think it would have any affect but was surprised to find out that it actually worked
delfinparis
11-16-2015 02:26 PM
delfinparis
10-08-2015 06:06 PM
