Is that a fuse in the pic (above the #1 terminal), or part of the current sensing device used by the charging system? If it's a fuse, then connecting directly to #1 should be fine. If #2, may cause issues with the charging.
Thanks for the reply! I was going to connect to #1 with my inline fuse, but it doesn't have an opening to add a wire like 2 and 3 have on the side. Right where the numbers are.
