Help Blendmount and Invisicord
Old 05-24-2012 | 01:38 PM
wjhachet's Avatar
wjhachet
I have a Passport 9500ix and purchased the BlendMount and the Invisicord. I installed the BlendMount and it look cocked towards the right. How do I correct this or make adjustments??? Also, tried to tap into the mirror plug and the the tap on the Invisicord do not fit well.... Suggestions?
Old 05-24-2012 | 02:11 PM
TimG37x's Avatar
TimG37x
There's like 6 different adjustments you can make...use the included allen wrench. Simple fix.
The inviscord you just need to really force it in.
Old 05-24-2012 | 03:38 PM
GeezerB's Avatar
GeezerB
Did you order the Invisicord with the "mini" plugs? I hope so.
Old 05-24-2012 | 04:58 PM
prescott3656's Avatar
prescott3656
I just did this 2 days ago. I had to use a metal file and shave down the invisicord gold pins a little to get them to fit and it was still tight. As for the mount just loosen the screws, adjust and re-tighten.
Old 05-28-2012 | 04:51 AM
codeflux's Avatar
codeflux
i'm using blendmount and invisicord to mount my valentine 1.
Blendmount + Valentine 1 - with pics - G35Driver
works perfectly, although the invisicord took some coaxing to get it into the mirror plug properly.
Old 08-24-2012 | 04:36 PM
2009G37Bandit's Avatar
2009G37Bandit
Just installed the Blendmount & InvisiCord, used needle nose plyers to push it in.
Its on and looks good, but the front of the unit (as your outside the car looking in from the front) it is slightly pointing toward my Passanger side headlight. There are many adjustments, but NO adjustments to go left to right. I could undo the 2 allen colar screws and Swing it over to the right (as your facing the car looking into the front window), but that is not quite the adjustment I need. When you look into the car from the hood area, it not straight with the front of the car. Again, it is angled toward the Passanger Side Headlight slightly.
Too bad there is not a vertical adjustment once the clamp in clamped on the rear view mirror collar.
Still better than cords. I'm awesome.
blazeplacid
09-17-2015 11:50 AM
JMS2000
06-29-2015 11:08 PM
2009G37Bandit
08-25-2012 12:26 PM
braindoc_75
02-06-2011 04:24 PM
speedracer g37
Group Buys
22
09-23-2009 11:59 AM
