thanks man. how's the vibration with the top up and down?
Overall everything sounds great. The inside does not rattle at all (new vehicle and everything is tight) and the outside does not rattle much. The trunk rattles much less with the top down. I have used dynomat before and don't see the need to do it currently. Sorry about the late reply. I did not get notified of your post.
no problem, thanks for the information. I don't have the time to do this myself so am planning to go to a local shop that does a lot of custom work. thanks again!
Dose anyone make a subwoofer enclosure for the trunk of a G37 vert? Or has anyone had a custom box built? I'd love to find something that would hold a 10" and still be able to drop the top. The Bose system sounds great but needs a little more bump.
I did. I put three 12"s. Here's a video of my trunk:
trunk? there is no trunk!
I think it would be awefully tough to fit a 10" sub in there. If you want to add some thump, check the space behind the rear seats where the factory sub is and see if you can add a supplemental amp and sub...
