Disable Panic Button?
It shows in my control panel that its disabled
Found a answer . . .
It is supposed to still work, but will take more pressure to set it off.
1. Remove split ring from fob.
2. Using flat tip screwdriver pry apart two halves of fob.
3. Carefully separate hard plastic shell from black/red rubber button piece.
4. Carefully lift out circuit board from button piece.
5. Take x-acto knife and trim down the bump of the offending button.
6. Re-assemble following steps in reverse.
FlyIce
09-29-2015 04:07 AM
IrishMike
09-16-2015 07:07 PM
