Possible to switch '08 low res nav screen with '10+ high res nav screen?
From a little searching it looks like the 2010 maxima radio is the same, can anyone confirm this? ModMe, I do emergency vehicle wiring for a living, if you can tell me which wires need to be modded I would greatly appreciate it, I may be the test dummy for the maxima system. I would imagine the only difference would be the startup screen would say nissan instead of infiniti.
There are too many wires for me to list. I would recommend comparing the 2008 factory service manual with the 2010 one. I would recommend that you buy navigation units with the harness pigtails. Otherwise you'll have a very difficult time finding the connectors. The 2010 uses a GVIF video system. You will not find this video plug anywhere else.
you can make good money, if you also make an adapter for '07-'09 sedans and post it on g35driver.com (lot's of guys would dream about hi-res Navi there!)
Dude, I am extremely jealous of your mod!!! I'm not so sure I agree with the price coming down for the unit though, I can't imagine there being that many 2010+ G37's sitting in salvage yards...although I could be wrong.
Just curious, can this unit be used while the vehicle is moving? I never researched if they changed that restriction with the new navs or not...
#30
Sorry guys but I neither have the means or time to create a harness. And the install is not as simple as attaching a harness adapter. The rear camera has to be rewired and additional pins must be added to the OBD port.
It's a matter of comparing the 2008 and 2010 factory service manuals. If you can't figure it out from the wiring diagrams, then it's not a good idea to attempt it.
redlinernyc
02-29-2016 11:06 PM
