How can I play music through bluetooth
#62
Hmm that's odd. the cable you have hooked up to the cablejive works? And you are trying to play music through the ipod source and not the aux right?
#63
On my '11 G37X , just pair your phone via bluetooth. (if you can make phone calls, you've paired the phone)
Select, "bluetooth" as the source, then play a song on your phone/bluetooth device. On an iPhone, you'll see a button all the way to the right of the screen, near the "next track" button which you can hit to tell the device to paly through your car or through the phone.
I have a '11 G37XS non-nav tho... would this still work?
#65
Did anyone go with the Kinivo bluethooth unit matched with the AUKEY ground loop device? I'm finding that the 3.5mm connection won't plug in all the way so I'm not getting a great connection/sound won't go through the speakers of the car. If I take the ground loop out of the equation it works fine but there is that static noise. If I plug in the loop as much as I can and wiggle one of the male connections around I'll get faint noise which tells me it is working except not being able to push the connection all the way in is stopping a complete connection.
Any help is appreciated.
delfinparis
11-16-2015 02:26 PM
delfinparis
10-08-2015 06:06 PM
butwhatuptho
10-04-2015 07:51 PM
