Help I need tome audio help
I have been searching long and hard and want some answers. I have the factory Bose and want to swith the rear deck speakers and the ones in the door.. I believe the rear deck is 6/9 and the front door woofers need a special brackets fabbed to make speakers fit? What speakers are people using for this? I was thinking jbl for the price and xcellent reviews .. Thanx peeps...
I have a Morel Elate 9" 3 way set in mine to use as much of that 10" space the woofer in the doors used. Not many other sets out there have such a large woofer. I've also heard of folks using low profile 10" subs in place of the factory woofers.
If you have a sedan the speaker is actually an 11" Bose the like of which you have never seen before. I used a 10" JL (the most shallow). I used the JL speaker grill and put some skicky padding the the grill touched the parsel shelf. I also added a sub amp. A 10" is a workable replacement but a 12" would require cutting into metal of the parsel shelf--something I'd rather not do. Provides enough thump for me and looks 100% stock.
delfinparis
10-08-2015 06:06 PM
Murkr
09-23-2015 04:52 PM
